BOV noises
keithmoilanen
BOV noises
Post by keithmoilanen »
Dont know where to put this or if it really has to do with the blow off vaulve but i was watching some old rally racing and they make some really cool sounds when down shifting and slowing down, or speeding up like a bunch of purges or something. i was wondering what it was and how to get that sound out of my t-leg.
well i guess the t-leg did not really make those sounds but i hear a lot of rally cars that do it.
http://m.youtube.com/watch?v=e7qp3srbsps
http://m.youtube.com/watch?v=2jiBF2mGxdw
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Re: BOV noises
Something like this?
http://www.youtube.com/watch?v=Ffj01k64AZI
If you want your car to sound like that you'll need an aftermarket BPV/BOV.
keithmoilanen
Re: BOV noises
Exactly like that thanks so what is a good one I should look for. Was it the Synchronic SB001 BOV? It sounds amazing I am confused on what exactly I need to buy.
So it's the surge I want correct?
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Thesubielover
Re: BOV noises
Post by Thesubielover »
My blitz bov doesnt seem to want to make any noise. Ive adjusted it at idle under the hood and gave it gas by the throttle body, but no surge sound. I either have to take it to get looked at, or i need a new bov. I tried to loosen it back where the valve would just barely let air out at idle, but nothing. Any tips would be great.
keithmoilanen
Re: BOV noises
I read it could be bad for the car
Next how to get my engine to sound like that
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Thesubielover
Re: BOV noises
It shouldnt be bad for the car. The only things that the bov does send the excess pressure to the air and the bpv shoots it back into the intake system. Different bov's make a number of sounds. Someone chime in and correct me if im wrong.
Re: BOV noises
It's probably not really bad for the engine but it's letting out metered air from the intake which causes it to run a little rich when you shift or let off the throttle. I don't know if this affects the ECU over time as it learns but I've always wondered that. To me it's just a silly noise that gets old after a while and attracts the wrong kind of attention. It can sound cool but it's a little obnoxious.
macipusy
Re: BOV noises
Post by macipusy »
BOVs are crappy for perfomance....its all just noise. Why let the air you already had in the system back out. A BPV is the way to go...helps to keep the turbo spinning between shifts and and doesn't screw with your AFR's between shifts and when you roll off the throttle a bit.
I say if you like the noise go for it, but if you are still running ther MAF based air metering, then its a performance downgrade.
Also, its hard to make a BOV blow off by revving while parked....you need some load on it to build boost in the system to blow off and make noise.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
keithmoilanen
Re: BOV noises
I have a bov already dumping into atmosphere it's pretty load I just like noise of the surges .
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Thesubielover
Re: BOV noises
Mine doesn't really even make noise under boost. Maybe I just have to mes with the adjusting screw more.
Re: BOV noises
Yeah robert it should definitely be making noise so you prob have to adjust it or something. I would run a bpv though if I was you.
Thesubielover
Re: BOV noises
I can hook my stock one back up. I like the bov sounds, meh whatever.
Re: BOV noises
The guy I linked to initially has some interesting, informational videos about BOV's, etc. Here's another from his channel.
http://www.youtube.com/watch?v=jEUWEsqo ... ure=relmfu
With my stock 91 SS BOV (that I determined was leaking since Idle was -10 on the boost gauge, and swapping in another brought it up to -18/19), it sounded like the above. With the new one (primary off a TT lol), it sounds like 0:50 onwards in the video.
While not as loud as his car by a long ways, putting in a "coffee cup" made me able to hear the compressor. It doesn't have the cool turbo flutter like with my old leaking, slow to open and close BOV did, the turbo spools up slightly faster and I hit target psi now.
keithmoilanen
Re: BOV noises
Any one know what they did to the engine in the second video I posted
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Re: BOV noises
keithmoilanen wrote:Any one know what they did to the engine in the second video I posted
What do you mean? Are you talking about a specific sound, or just in general what was done to the engine?
keithmoilanen
Re: BOV noises
to the engine cause I want my engine purring like that
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Re: BOV noises
Get a twin scroll turbo setup with a huge external wastegate, run a cone filter right off your turbo with a bov and straight pipe off the turbo 3"+.
keithmoilanen
Re: BOV noises
Alright time to look into some new stuff
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Apex3
Re: BOV noises
Post by Apex3 »
Mine is pretty damn loud with the stock bpv. Desnorkus, coffee cup mod, and intake will all make it much louder, and will cost less than a BOV
It's a rally car though, it won't sound exactly like that without some serious work. Part of what you're hearing is the turbo itself, ours are tiny and low boost so they don't make a whole lot of noise, though again, with the mods above mine makes a lot of noise, no whistle to it though.
Re: BOV noises
I think I heard yours. Were you at wcss last year? Someone with a whinestone ss had a really loud bov. I remember that. Sounded ridiculously loud for how slow it was going.
Re: BOV noises
Florin's BOV was vented to atmosphere and it was pretty loud. IIRC he was getting around 16mpg though.
keithmoilanen
Re: BOV noises
i have intake 3 1/2 exhuast bov...
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Re: BOV noises
Get an external wastegate and cone filter.
keithmoilanen
Re: BOV noises
I have a summit racing cone filter on right now
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Rubasu
Re: BOV noises
Post by Rubasu »
I have a turboxs RFL type-h BOV and i love it. it blows off at 115db's. i dont have any problems.
http://www.youtube.com/watch?v=44JFZ0Yz ... re=related
But after this video i want that other one.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
