Page 1 of 2
BOV noises
Posted: Wed Jun 27, 2012 5:38 am
by keithmoilanen
Dont know where to put this or if it really has to do with the blow off vaulve but i was watching some old rally racing and they make some really cool sounds when down shifting and slowing down, or speeding up like a bunch of purges or something. i was wondering what it was and how to get that sound out of my t-leg.
well i guess the t-leg did not really make those sounds but i hear a lot of rally cars that do it.
http://m.youtube.com/watch?v=e7qp3srbsps
http://m.youtube.com/watch?v=2jiBF2mGxdw
Re: BOV noises
Posted: Wed Jun 27, 2012 6:11 am
by mike-tracy
Something like this?
http://www.youtube.com/watch?v=Ffj01k64AZI
If you want your car to sound like that you'll need an aftermarket BPV/BOV.
Re: BOV noises
Posted: Wed Jun 27, 2012 7:11 am
by keithmoilanen
Exactly like that thanks so what is a good one I should look for. Was it the Synchronic SB001 BOV? It sounds amazing I am confused on what exactly I need to buy.
So it's the surge I want correct?
Re: BOV noises
Posted: Wed Jun 27, 2012 9:02 am
by Thesubielover
My blitz bov doesnt seem to want to make any noise. Ive adjusted it at idle under the hood and gave it gas by the throttle body, but no surge sound. I either have to take it to get looked at, or i need a new bov. I tried to loosen it back where the valve would just barely let air out at idle, but nothing. Any tips would be great.
Re: BOV noises
Posted: Wed Jun 27, 2012 9:27 am
by keithmoilanen
I read it could be bad for the car
Next how to get my engine to sound like that
Re: BOV noises
Posted: Wed Jun 27, 2012 9:58 am
by Thesubielover
It shouldnt be bad for the car. The only things that the bov does send the excess pressure to the air and the bpv shoots it back into the intake system. Different bov's make a number of sounds. Someone chime in and correct me if im wrong.
Re: BOV noises
Posted: Wed Jun 27, 2012 3:34 pm
by kimokalihi
It's probably not really bad for the engine but it's letting out metered air from the intake which causes it to run a little rich when you shift or let off the throttle. I don't know if this affects the ECU over time as it learns but I've always wondered that. To me it's just a silly noise that gets old after a while and attracts the wrong kind of attention. It can sound cool but it's a little obnoxious.
Re: BOV noises
Posted: Wed Jun 27, 2012 5:05 pm
by macipusy
BOVs are crappy for perfomance....its all just noise. Why let the air you already had in the system back out. A BPV is the way to go...helps to keep the turbo spinning between shifts and and doesn't screw with your AFR's between shifts and when you roll off the throttle a bit.
I say if you like the noise go for it, but if you are still running ther MAF based air metering, then its a performance downgrade.
Also, its hard to make a BOV blow off by revving while parked....you need some load on it to build boost in the system to blow off and make noise.
Re: BOV noises
Posted: Wed Jun 27, 2012 11:18 pm
by keithmoilanen
I have a bov already dumping into atmosphere it's pretty load I just like noise of the surges .
Re: BOV noises
Posted: Thu Jun 28, 2012 2:31 am
by Thesubielover
Mine doesn't really even make noise under boost. Maybe I just have to mes with the adjusting screw more.
Re: BOV noises
Posted: Thu Jun 28, 2012 2:55 am
by kimokalihi
Yeah robert it should definitely be making noise so you prob have to adjust it or something. I would run a bpv though if I was you.
Re: BOV noises
Posted: Thu Jun 28, 2012 3:10 am
by Thesubielover
I can hook my stock one back up. I like the bov sounds, meh whatever.
Re: BOV noises
Posted: Thu Jun 28, 2012 3:29 am
by mike-tracy
The guy I linked to initially has some interesting, informational videos about BOV's, etc. Here's another from his channel.
http://www.youtube.com/watch?v=jEUWEsqo ... ure=relmfu
With my stock 91 SS BOV (that I determined was leaking since Idle was -10 on the boost gauge, and swapping in another brought it up to -18/19), it sounded like the above. With the new one (primary off a TT lol), it sounds like 0:50 onwards in the video.
While not as loud as his car by a long ways, putting in a "coffee cup" made me able to hear the compressor. It doesn't have the cool turbo flutter like with my old leaking, slow to open and close BOV did, the turbo spools up slightly faster and I hit target psi now.
Re: BOV noises
Posted: Thu Jun 28, 2012 8:25 pm
by keithmoilanen
Any one know what they did to the engine in the second video I posted
Re: BOV noises
Posted: Fri Jun 29, 2012 5:57 pm
keithmoilanen wrote:Any one know what they did to the engine in the second video I posted
What do you mean? Are you talking about a specific sound, or just in general what was done to the engine?
Re: BOV noises
Posted: Fri Jun 29, 2012 7:55 pm
by keithmoilanen
to the engine cause I want my engine purring like that
Re: BOV noises
Posted: Fri Jun 29, 2012 8:52 pm
by kimokalihi
Get a twin scroll turbo setup with a huge external wastegate, run a cone filter right off your turbo with a bov and straight pipe off the turbo 3"+.
Re: BOV noises
Posted: Fri Jun 29, 2012 11:14 pm
by keithmoilanen
Alright time to look into some new stuff
Re: BOV noises
Posted: Sat Jun 30, 2012 3:03 am
by Apex3
Mine is pretty damn loud with the stock bpv. Desnorkus, coffee cup mod, and intake will all make it much louder, and will cost less than a BOV
It's a rally car though, it won't sound exactly like that without some serious work. Part of what you're hearing is the turbo itself, ours are tiny and low boost so they don't make a whole lot of noise, though again, with the mods above mine makes a lot of noise, no whistle to it though.
Re: BOV noises
Posted: Sat Jun 30, 2012 3:27 am
by kimokalihi
I think I heard yours. Were you at wcss last year? Someone with a whinestone ss had a really loud bov. I remember that. Sounded ridiculously loud for how slow it was going.
Re: BOV noises
Posted: Sat Jun 30, 2012 3:31 am
by mike-tracy
Florin's BOV was vented to atmosphere and it was pretty loud. IIRC he was getting around 16mpg though.
Re: BOV noises
Posted: Sat Jun 30, 2012 3:52 am
by keithmoilanen
i have intake 3 1/2 exhuast bov...
Re: BOV noises
Posted: Sat Jun 30, 2012 4:16 am
by kimokalihi
Get an external wastegate and cone filter.
Re: BOV noises
Posted: Sat Jun 30, 2012 6:01 am
by keithmoilanen
I have a summit racing cone filter on right now
Re: BOV noises
Posted: Sat Jun 30, 2012 6:06 am
by Rubasu
I have a turboxs RFL type-h BOV and i love it. it blows off at 115db's. i dont have any problems.
http://www.youtube.com/watch?v=44JFZ0Yz ... re=related
But after this video i want that other one.
