03 Rex springs?
killajamal
03 Rex springs?
Post by killajamal »
Would 03 wrx sedan struts and springs bolt up to a 94 leggy turbo wagon? A set just popped up on CL for a reasonable price.
Holla atcha boy.
jp233
Re: 03 Rex springs?
Post by jp233 »
I think yes, go look at the sticky thread for the compilation of a ton of suspension info.
But, I think the spring rates from the WRX sedan are a lot lower than the 1st Gen wagon.
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
killajamal
Re: 03 Rex springs?
Thank you sir!
I briefly looked over some of the suspension stickies and it looked like i might need new perches?
Im not too saavy on suspension or anything for that matter. But would a lower spring rate just make the car much stiffer?
Re: 03 Rex springs?
There is a recent thread talking about the compatibility of the struts.
http://bbs.legacycentral.org/viewtopic.php?f=6&t=45965
James614
Re: 03 Rex springs?
Post by James614 »
Personally, I'd keep the rear springs from your Touring Wagon. Touring Wagon rear springs are firmer than any Impreza except the STI (even harder than WRX wagons). STI rear springs are about the same.
killajamal
Re: 03 Rex springs?
Really? I was definitely unaware of that. The rear actually sits pretty close to where I'd like. It's just the front of the car is so dang high! Same with my 98 GT.
These wagons handle like boats from the factory in comparison to my 2nd gen legacy.
James614
Re: 03 Rex springs?
Post by James614 »
If the rear is lower than your front, then your springs or struts are toasted back there. The rear of a Touring Wagon should sit higher thanm the back.
Re: 03 Rex springs?
Check the wheel arch measurement against this info to see if your touring wagon is sitting where it should be, or if the springs are sagging.
http://www.main.experiencetherave.com/s ... s_1994.jpg
