aftermarket water temp sensor.
logan9691
Post by logan9691 »
Wondering where people have placed there temp sensors for after market guages. Looking to get an innovate G3 guage but I'm not sure where to mount the sensor since the adapters for newer subies look like a tight fit with our radiator hoses.
Logan.
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
dscoobydoo
Re: aftermarket water temp sensor.
Post by dscoobydoo »
The engine outlet to heater core line.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
macipusy
Post by macipusy »
^^^Yes! I built a T from brass pieces, spliced it into the heater core hose and installed my water temp in that pointing down to make sure there is liquid touching it all the time. I checked the temps at the T vs the stock sensor location and at most they were 2 degrees off.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
