newer alt on a older legacy
turbo970
Post by turbo970 »
i was wondering if the alternator s from a newer subie will work on my 92 legacy. something that will have a touch more amperage that the stock alt thanx for all your help with this
Re: newer alt on a older legacy
Yes, the newer subaru 2-pin alternators will work on your 92 Legacy. You will need to get the new plug and splice it into the appropriate wires on the stock alternator harness.
oldscoobyturbo
Post by oldscoobyturbo »
works great and its necessary with detla cams
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
martimus919
Post by martimus919 »
diesel devil wrote:works great and its necessary with detla cams
I'm curious as to why this is? I don't see how they're related but am eager to find out.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
oldscoobyturbo
with the delta cams the idle is rough and the rpms are not stable so the stock alternator has a hard time keeping the lights from flickering.
martimus919
Ah! I like it, makes sense, thanks for the explanation man.
But newer alts are easy to install on these, I'm running one on my Brat just fine.
07 Outback XT VF52
george 2022
Post by george 2022 »
turbo970 wrote:i was wondering if the alternator s from a newer subie will work on my 92 legacy. something that will have a touch more amperage that the stock alt thanx for all your help with this
Good morning. I want to do the same thing to my car .upgrade the early one with a newer.was your alt 3 plug wires or 4 plug round wires?
george 2022
Legacy777 wrote:Yes, the newer subaru 2-pin alternators will work on your 92 Legacy. You will need to get the new plug and splice it into the appropriate wires on the stock alternator harness.
Hi. I want to do the same thing.my alternator has the the round plug with 4 wires Hitachi. I think the 4th one which is green with black stripe (D)goes to the ECU for some kind of Ecu control..I am not sure .I can not find a wiring diagram for this JDM ECU G2 226611AA950. The most early legacys 1990-4 came with 3 wires round alternator plug.!!!That's why I aske if it is possible to make the upgrade ?
So are you saying that you have four wires in the wiring harness going to the alternator? If so, that's the first time I've seen that and am not sure what it would do to the ECU and if you would be able to upgrade.
Josh, we started a new thread and continued the conversation here:
http://bbs.legacycentral.org/viewtopic.php?f=19&t=55379
