Diamond coil pack from n/a, brake light comes on intermitten
alexandermf
Post by alexandermf »
Two questions:
I have a 2.2l n/a diamond coil pack from an older legacy of mine and was wondering if its compatible with my 93 legacy turbo. I just know they're great coil packs and would love to replace the shitty one on there.
Secondly, my ebrake light comes and goes as it pleases, my brake fluid is NOT low, my buddy says the switch is possibly stuck? Not sure where to go on this one, my brakes are extremely low and need to be done, to the point my ebrake doesn't even work
Sent from your bathroom closet
Doaomo
Re: Diamond coil pack from n/a, brake light comes on intermi
Post by Doaomo »
The diamond coil pack is a common upgrade for our cars. Read a little before posting...
As mentioned, you can swap the coil pack over easly.
Regarding the brake light, you can try tapping the little float in the brake fluid resevoir to see if it bounces back up. Where does the line of brake fluid come up to on the resevoir?
alexandermf
Ah gotcha, I figured there were two diff types of the diamond, one for the na and one for the turbo cuz the wire plug in seems to be a lil diff but thnx, and ya I tried tapping the float, ill clean the reservoir and tank when I do a brake fluid flush and see if that helps
The electrical connector should be identical as long as you have the correct diamond coil pack.
alexandermf
Figured it out, he diamond plugin was just broke to crap so it wasn't fitting right but I got it, thx
