I'm wondering what the differences are between a "TM702KE1AA and TM752RX3AA"
TM702KE1AA My 91' Subaru Legacy
TM752RX3AA 93-94' Subaru Impreza
can i fit impreza transmission to my legacy ?
edit:i corrected transmission code.
Transmission Codes
Transmission Codes
Re: Transmission Codes
I can't find the "TM752K1AA" code anywhere, I think maybe you missed a letter in it?
Yes, the Impreza trans will physically fit. If you're FWD, you are good. If you are AWD, you need to match the rear end ratio to the trans ratio of the new trans.
i could not find..i will look again.yes my car is fwd but my doubt imprezas has 90 hp my car has 115 hp can it be problem. ?Alphius wrote:I can't find the "TM752K1AA" code anywhere, I think maybe you missed a letter in it?
You should be fine. It will work just as good. The Subaru transmissions were not any different with different power levels (until you get to the WRX/STi level.)
thanksAlphius wrote:You should be fine. It will work just as good. The Subaru transmissions were not any different with different power levels (until you get to the WRX/STi level.)
my transmission code:TM702KE1AA
