Clutch Spring
robertpaige
Clutch Spring
Can anyone tell me what this actually does? Because I noticed it was unhooked and hanging on one side, so I took it off. I think I still have it laying around. From what i've seen the purpose is to limit the extra play in the clutch fork for a tighter feel? Is it safe to keep it off? Here is an image from Kimo's Legacy but I couldn't find a solid answer within those posts
Re: Clutch Spring
It adds a positive feel to the clutch pedal, and returns the fork to the home position faster than the hydraulics would. So marginally less clutch disk wear over time?
- quasi-mod-o
Clutch Spring
It probably also keeps the throwout bearing from dragging against the pressure plate while the clutch is engaged.
So I'd put it back on to keep from wearing out your throwout bearing too fast.
Re: Clutch Spring
Wouldn't returning the fork require the spring go in the other direction? Its pulling the fork the same direction the slave cylinder pushes it to disengauge the clutch. I think its only there to keep it from rattling.
Re: Clutch Spring
It's there to keep the clutch fork play to a minimum and may help with rattling...
Re: Clutch Spring
Ive never had it on my car
robertpaige
Re: Clutch Spring
you know, i've been hearing some rattling and I bet you this is the culprit. I couldn't figure out where it's coming from, sounded like the top hat to the front left was maybe coming loose, but it wasn't. Where can I get another spring? the dealer? cause this looks like a special fitting spring.
Re: Clutch Spring
Dealer.
Re: Clutch Spring
Kimo, didn't you replace yours? Still have part numbers?
Re: Clutch Spring
Part # for the spring is 30546AA030
Re: Clutch Spring
I have a brand new one but I'm holding onto it in case I lose mine again. I ordered one and found mine before it came.
