94 Legacy Radiator
robertpaige
94 Legacy Radiator
Post by robertpaige »
Radiator is most likely cracked, overheated and was pouring coolant.. checked all hoses and hose clamps, and also changed drain plug no change. will a radiator from a 95-99 fit in a 94'? looks like the same dimesions, anyone got any feed back?
Re: 94 Legacy Radiator
I believe it may fit, but what might be an issue is if you have an automatic trans, the trans cooler lines might be at different spots. This thread has some more information.
http://bbs.legacycentral.org/viewtopic.php?f=5&t=48162
