BG trans swap questions
slaytalera
Post by slaytalera »
I picked up a JDM trans to swap into my BG and have some questions. Would the axles work from my SS manual, and would the driveshaft from my SS work?
The trans is out of a impreza with a 4.444 gear ratio, the guy thinks it might be out of an RA but I won't find out till this weekend if it matters
Re: BG trans swap questions
Yes I believe the axles should work. As for the driveline....I think it might, but you'd probably want to get confirmation.
PhyrraM
Post by PhyrraM »
There are some differences in the size and bolt pattern of the companion flange on the rear differentials, so keep an eye on that.
slaytalera
Thanks Legacy777
And phyrra ill keep an eye out, my stock diff is 4.444, but im getting the lsd as well so one should work
