$3500
There were only 4000 Turbo's made in 1994. Rare Wagon
The car has 259,057 miles on it. Daily driver and maintain at the Subaru Dealership I work at. I work in Parts. New Paint Job: Original Color. 3rd Owner.
I have a lot of stock part still for it.....
NOT SALVAGED!!!!
This is pretty much stock except the following:
Alarm
Cat-Back Magnaflow
2006 Legacy GT 2.5 17" Wheels
5% Window Tint
After Market Radio
4 New JVC speakers
Front WRX Rotors and Calipers and Brakes
KYB-GR2 Struts
New Front WRX Rotors and Pads
New Rear Rotor and Pads
Timing Belt and all the Idlers and seals were all done at 200,000. It has the 105,000 belt on it. Water pump and Thermosat
HID Lights
The first Transmission is brand new 3 years old.
Comes with a Second New OEM Transmission box. (Part number 31000AC290R1 $2978.17)
Engine is all stock, Turbo is all Stock. The cleanest engine you will see......
This will be the cleanest Legacy you will see......
The following item's gettting repaired:
Spark Plugs - FIXED
Brand New Seat Cover top and bottom will be Repaired. Driver Sides - FIXED
Sunroof work's and Tilt's. It has all new parts. It doesn't leak
Chris - call me or text me at 916-416-9677
