ej207 version 7 ecu diagram
91legacyawdturbo
Post by 91legacyawdturbo »
Does anyone have an jdm ej207 Version 7 ecu pin layout/diagram?? i can only find a edm diagram might have slight differences???
2002 wrx sport wagon
Re: ej207 version 7 ecu diagram
What year & model subie did that particular setup come in?
PhyrraM
Post by PhyrraM »
A V7 is *close* to a USDM WRX ('02-'03).
Check the more mainstream sites like Nasioc for links to diagrams.
91legacyawdturbo
Legacy777 wrote:What year & model subie did that particular setup come in?
Josh I believe the swap is from a 2002 japanese bugeye sti gdba4eh chassis
Ej207dw3cr is the engine type. We bought the engine and trans from Canada, the company we bought it from had messed up their listing for a gc8 sti ej207 version 6 front half cut that they didn't have anymore , so instead we worked out a deal for a version 7 but they wouldn't send us the half cut just the engine, transmission all of the wiring and all of the necessary parts for the swap, but nothing else.
PhyrraM wrote:A V7 is *close* to a USDM WRX ('02-'03).
I have right after I did the op I found a ecu pin diagram. Nasioc is a pita to find certain things that end up in waisting 10 hours to find junk, i got fed up with the craptastic search engine nasioc has, plus the whole thread on ecu pin layouts are crap since the version 7/8/9 arent listed in the thread. The fsm I've found is the uk version, wasn't sure how much the edm to jdm differences where. I have found out the 02-03 wrx is similar to the sti besides the 8 wires that subaru had blocked off on the USDM wrx. Thanks for the help.
I've got the 02 WRX FSM if you're interested in that....but I don't have much overseas stuff for the newer subies.
