water is everywhere
subie is a monster
water is everywhere
Post by subie is a monster »
this morning i sat in the subie and thare is a lake at my feet. in all four floor boards but the thang is everything is dry. i can not find where the leak is.
Last edited by subie is a monster on Mon Oct 08, 2012 7:41 pm, edited 1 time in total.
Re: yup
Does it smell like coolant or do you have know if there's coolant in your engine or just water?
Someperson
Re: yup
Post by Someperson »
umm did you leave ur sunroof open? lol
93 Winestone TW project
subie is a monster
Re: yup
sunroof is closed and it is not antifreeze honestly im stumped
FundamentalyConfused
Re: yup
Post by FundamentalyConfused »
Did it rain last night? My 90 Leggy has had the windshield replaced and there's some rusting at the top of the windshield and I"m pretty sure that's what's causing moisture to get into my subie. Not sure for yours tho.
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
wtdash
Re: yup
Post by wtdash »
Please update your Subject/Title for this thread.
Common issue is for the sunroof's drains to get plugged. Then the water ends up INside. Many just seal it closed as it's a PITA to fix, from what I've read....but read up on here about it.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
subie is a monster
Re: yup
changed the sunroof and cleared the tubes about a month ago they looked good :smt021
subie is a monster
Re: yup
about to just take the carpet out and put in drain holes
Someperson
Re: yup
Weather seals on the windows?
Re: yup
subie is a monster wrote:changed the sunroof and cleared the tubes about a month ago they looked good :smt021
Did you run some cable down the tubes all the way til you had like 4 feet of cable into the tubes? You can often see dirt falling beneath the car when you do this.
subie is a monster
Re: yup
i did it with compressed air but possable it did not work the first time. atleast i will not have to pull the sunroof back out. it is heavy and annoying
subie is a monster
Re: yup
i just replaced all of the interior out of a 94. PITA
subie is a monster
Re: yup
Someperson wrote:Weather seals on the windows?
cracked in some spots
subie is a monster
Re: yup
that was it. i took a hose to it today and saw it leaking near the bottom of the window
Someperson
Re: water is everywhere
Glad to have helped, it's typical of older cars had a Sebring that the convertible top went and didn't find the leak in time... Sucked
That'll do it. One of the earlier things on the expensively long list of remedies to brand new DeLoreans that jacked up the price when they arrived in the US from Ireland was replacing the weatherstripping. The people they had building them had no idea what they were doing—many didn't even own cars—so they would cut the weatherstripping into pieces to make it easier to instal.
subie is a monster
did not know that. it is weird what people will do.
subie is a monster
now to adress the lake in my trunk. i found it while takeing out my antenna because radio sucks in the mountains. and thare it is right under the antenna in that deep recess to the left filled to the drain tube for the sunroof where it exits the car. put some water in the tube and it drained properlyso it is not that.
any ideas
Someperson
Stripping on the trunk? Mine has the same issue so tell me what u find
Danny-G
Post by Danny-G »
I had that problem for a while. It turned out there was a small rubber plug missing under the tail light. I would check the tail light sealant as well as checking for that rubber plug.
Danny
There are also breather flaps behind the bumper....if they are missing, it's possible water is getting in from there....but I would start with the tail light first.
Here's a pic from the 06 Legacy, but you get an idea of where the flaps are
http://www.main.experiencetherave.com/s ... G_6222.JPG
