Code 45
03bug
Code 45
Post by 03bug »
So I just got done with my rob tune vf39 and fmic. I have a code 45 I changed both the solenoid and the sensor and the code is still there. Driving the car once I get to about 4k it falls on its face and stumbles, sometimes the motor will die too. Also at idle the motor dies everonce in a while but it doesn't stumble or anything it just seems like the powere gets cut.
wtdash
Re: Code 45
Post by wtdash »
Hi,
You did this, correct?:
Wiring
The ignition differences are described above, but the MAP sensor also needs addressed. Otherwise, it'll throw a code - 45. The solution is to remove pin 5 on B48 and join it with pin 21 on B48 @ the ECU connector.
It's part of the swap when using the EJ20G ECU.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
