tire tech help
turbo970
tire tech help
Post by turbo970 »
i decided to get a set of new tires after the car gets out of shop. i'm wanting something a tad lower and wider than the stock 195 60 15's. what tire size will work for what i'm wanting
Re: tire tech help
Are you planning on sticking with 15" wheels?
Typically when you go with a little lower profile tire it's good to upsize the rim so your overall tire diameter stays the same. I'm running 205/50 R16's and am pretty happy with them.
turbo970
Re: tire tech help
Post by turbo970 »
tire budget doesnt include rims just the rubber
Re: tire tech help
If you're sticking with 15" wheels, I'd probably just recommend sticking with the stock size.
