'93 Legacy SS rear bearing/hub
Posted: Mon Oct 08, 2012 9:22 pm
hi,
I have a '93 SS that is need of new rear wheel bearings. I have heard that it is much easier to just replace the entire hub assembly (with bearing already pressed onto hub) than just changing the bearing alone. I know that one way to get these parts is to goto the junk yard and pull them off of an old car. However, I would like to replace my old hub/bearing with new ones.
My quesiton is, does anyone know of a place where I can buy a hub/bearing assembly (with the bearing already installed) for my '93 SS? All I can seem to find online is hub and bearings sold seperately. I've heard that this hub assembly is the same as the '02 wrx... is this correct?
Much thanks for any info you can provide!
