Pink & Pull Find in Tacoma/Lakewood
Not too sure if they're actually sti struts but they're red. The Shock isn't removable like the set I have on my car. Someone should o snag them. Also it had a sorter shifter on it (5MT) Owner has the shifter cut and welded. All 4 struts are there. 1991 Wagon
martimus919
Re: Pink & Pull Find in Tacoma/Lakewood
Post by martimus919 »
They may just be KYB AGX struts, still a good find. I'm running them on mine and I really like them.
If there are adjustment knobs on the back or on the top of the front struts than they're AGX's.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
Another easy way to tell is the shaft dia. STi are a beefy 46mm.
SuperRallyRoo
Post by SuperRallyRoo »
those are kybs agx with wrx front rotors. I know cause I took the calipers.
Legacyless
98 Jetta TDI
SuperRallyRoo wrote:those are kybs agx with wrx front rotors. I know cause I took the calipers.
When was this? Are the struts still there?
Stephen, i just bought them today. AGEs with adjustable dampening. Will be for sale shortly :-)
Stephen, i just bought them today. AGXs with adjustable dampening. Will be for sale shortly :-)
cj91legss wrote:Stephen, i just bought them today. AGEs with adjustable dampening. Will be for sale shortly :-)
Don't forget what good friends we are.
