92 leg sedan lift??
92 leg sedan lift??
I'd like to loft my legacy sedan what will net the most lift with struts? 02 forester struts and springs, reuse my top mounts and add camber bolts to correct geometry?
						Re: 92 leg sedan lift??
I don't have an answer for you, but welcome to the BBS.
Hopefully one of the other members will reply.
Hi,
Lots (and lots) of posts on here and over on USMB about lifting your Legacy.....short answer on the Forester: They'll fit but you'll have the 'saggy butt syndrome' and need spacers..
Best option is '96-99 Legacy Outback - they are plug and play...If you can use your top hats (might not fit if tapered springs).
GL,
Td
GL,
Td
							Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
				devilzdriver
I lifted my 92SS foresters are a pain.... im rocking impreza OBS, W/ Legacy Springs, and group N top hats i got about an inch over stock... i can post pix. its been workng great in rallyx and some trails ive gone down...
ll lifted! Went with 02 forester struts . Subframe spacers .control arm rear drop brackets . My cv axles s love me again.
 Next up....some whooosh!
