robtune on ej22t?
robtune on ej22t?
Im looking for some kind of piggy back or robtune (which i would prefer) but i havent found if its compatible with the ej22t? So im wondering if it is?
Re: robtune on ej22t?
http://bbs.legacycentral.org/viewtopic.php?f=19&t=43744
TL;DR:
Won't work on ej22t ecu, will work on ej20g ecu running an ej22t.
What is needed to run an ej20g ecu?
http://bbs.legacycentral.org/viewtopic.php?f=19&t=47252
TL;DR:
dscoobydoo
I gave him (Rob) my other 93 SS for months to try and work out the 22t ECU. He pretty much said something about the programming, the board, etc etc were all not able to be hacked to be adjustable.
Since he had already figured out the 20G ECU, he took my car and figured out how to make the 20G ECU work with the 22T wiring/ignitor/coilpacks.
His 4 to 2 ignition converter is that solution.
My White car has a PP6 piggyback, and it does not run as good as the 20G ecu car.
The only hiccup with the 20G ecu is the cold start issue- where it will start then stop immediately, but have no issues the second time.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
