Difference in the engine for a ej22 or a ej22 turbo
the Fatness
Post by the Fatness »
Hey im New to subaru here and was wondering what are the differences as far as putting a turbo on a N/A ej22 or is this just not done... i just picked up a 91 legacy wagon ej22 5mt that im thinking of a few mods.. also i know this is the wrong area but is the turbo hood a direct "bolt on" for a non turbo?
Happiness is not a matter of intensity but of balance, order, rhythm and harmony....... or get a bigger Turbo
Alphius
Re: Difference in the engine for a ej22 or a ej22 turbo
Post by Alphius »
The turbo hood is a direct bolt on.
Someperson
Post by Someperson »
http://forums.nasioc.com/forums/showthr ... 649&page=2 reddevil's rediculous 30 psi N/A twin charged beast. I had the same question a month ago lol
93 Winestone TW project
Welcome to the BBS.
I'd suggest searching the BBS. There are a lot of threads with info on the differences, and what it takes.
Check out Someperson's recent thread as a starter.
http://bbs.legacycentral.org/viewtopic.php?f=5&t=50284
the Fatness
thanks.. I figured it was like my rx7 and a direct bolt on for the hood... and the engine from what i read there seems like i need a lower compression and to drill the heads for the oil then strap on the bold on stuff and your good
robertpaige
Post by robertpaige »
the Fatness wrote:what i read there seems like i need a lower compression and to drill the heads for the oil then strap on the bold on stuff and your good
Not exactly. Sure you can throw on a turbo and get it to work but it will be a ticking time bomb if you're running it over 3-5psi and even then it's playing with fire. If you want to run a turbo on an N/A motor you want to go in and replace your stock internals with forged internals (rods, pistons, bearings, crank) if you plan on long term use of a turbo on an N/A EJ22.
Rubasu
Post by Rubasu »
plus you will need a turbo cross member for a uppipe to fit. so you can even have a turbo.
90 legacy Wagon LS Special, JDM closed deck 20g, custom 25d heads f/ metic motors, APS GC FMIC, 740cc, VF34, 4.11 F/D, Turboxs RFL blow off valve, now with piggyback.
94 Legacy SS R.I.P (parts car now for 90)
97 Legacy Outback (sold)
