Using 4.11 rear diff from 98 forester, what axles to use?
tsbpenguin
Working on installing the rear diff from a 98 forester to complete my 5mt and ej22t swap. The forester axles seem to be too long and I'm not sure if the outer joint is the same. Are there any other factory axles I should run, or will swapping on bc legacy outer joints solve my problem?
In between Subies
Re: Using 4.11 rear diff from 98 forester, what axles to use
I just installed 2 vlsd rear ends one in my 90 which all I needed was second gen. Legacy axles.
Charles
If you need a set of male axle for that, i have a set. Came off a 95 legacy brighton
tsbpenguin
Thanks! Took my forester axles back to Super Rupair in Boulder and they swapped em for 2nd gen legacy axles for me. Fit perfectlyrallyak wrote:I just installed 2 vlsd rear ends one in my 90 which all I needed was second gen. Legacy axles.
In between Subies
