Will a WRX flywheel work with a 90-96 Legacy PP/Clutch disk?
hellosubaru
Post by hellosubaru »
I'm doing a 5MT swap, and I have a WRX flywheel that was just machined. I'd like to use it with my clutch kit I just purchased for my Legacy. It's a non-turbo trans if that matters.
Will the WRX flywheel work with the NA Legacy clutch kit?
Thanks,
-Jason
-Jason
1986 GL - EJ22t .020 over - AWD 4.44 5spd - TD05 - '06 WRX TMIC - 3" turbo back exhaust - 440cc gray tops - JECS MAF - Robtune EJ20 ECU with EJ22 ignition converter
Re: Will a WRX flywheel work with a 90-96 Legacy PP/Clutch d
Jason,
What year/style of WRX flywheel is it for? If it is for the pull style found on the 02-05 it won't work with the non-turbo clutch setup.
I know in later years they changed the WRX clutch to the push style. So if the flywheel is meant for one of those transmissions, it may work.
hellosubaru
It is for the pull style (it's out of a 2002 WRX). I had originally purchased all turbo clutch parts, because I was told the transmission I purchased was a turbo trans. When I received the trans, it was quite a different story.
It sounds like I'll have to find an NA Legacy flywheel then. Thanks!
-Jason
Yup, you'll need a non-turbo flywheel. Good luck.
