will these snow tires fit?
vic subi
Post by vic subi »
hey just wondering if these snow tires will fit i already have them and rather not sell, so if i can make them work that be great.
1993 legacy L wagon stock
stock tire 185/70/14
snow tires 205/70/14
will they clear the strut? rub on fender? i dont mind rolling the fender lip if it means i can use them.
thanks in advance bbs
James614
Re: will these snow tires fit?
Post by James614 »
Fits fine. I've seen that size on Legacies/Imprezas a few times before.
vic subi
Post by vic subi »
okay thank you. guy at the tire shop said he wouldnt put them on because according to him they wont fit. anyone with personal experience use this size?
I think they'll be a little on the tall size, but may work. According to http://www.miata.net/garage/tirecalc.html
The stock tire (185's) will have the following specs:
Sidewall: 5.1 in
Radius: 12.1 in
Diameter: 24.2 in
Circumference: 76.0 in
Revs/mile: 834.0
New tire (205) will have following specs
Sidewall: 5.6 in
Radius: 12.6 in
Diameter: 25.3 in
Circumference: 79.5 in
Revs/mile: 797.0
Speedometer reading with non-stock tire is 4.6% too slow.
When your speedo reads 60 mph, you are actually traveling 62.7 mph.
vic subi
Post by vic subi »
Thanks josh i tried that calculator thing too. Im not concerned about the speed difference just if ill rub on the strut.
James614
Post by James614 »
It will definitely not rub the strut.
vic subi
Post by vic subi »
okay awesome thanks a lot guys
