93 legacy loosing power
turbolegacy93
Post by turbolegacy93 »
My 93 ss is running top mount, greddy bov, manual boost and open downpipe(stock). It tuns perfectly fine until it starts to build boost once it goes past the 0 on the boost gauge. You can't get on it at all. Have any of you ha this problem? There is no cel.
Re: 93 legacy loosing power
Usually if you have this kind of problem it's related to a pressure sensor or something not right with the electronics.
You may want to try running the "active" diagnostics with the green connectors
robertpaige
Post by robertpaige »
Sounds like it also might be a vacuum leak, I would check all of your vacuum lines. Do an active diagnostics check and post back an codes you might get.
turbolegacy93
Thanks for the impute guys! And I checked the black connections and it has two long flashes followed by two short flashes, so is that a 22 ( knock sensor ) I haven done the green connectors yet.
Ok, yeah check the green connectors, see if anything comes up, clear the codes and see what, if anything comes back.
