Cut Bump Stops or not?
georryan
Post by georryan »
I am replacing my AGX struts (sold them to my brother) with a set of Koni inserts on 2.5RS struts out of a GC8. I'm keeping my prodrive p1 springs. I figured it was a good time to replace my rear bump stops since I knew they needed some replacement. The p1 springs gave me about an inch drop and I was wondering what the thought was on cutting the bump stops: good idea or bad idea? Has anyone done it? What do you think? I've been running with stock bump stops for several years now, and I don't think its been too bad, but figured I'd ask. I have been scowering around and haven't really been able to come up with a strong decision on what to do.
I'm actually quite curious how the konis will compare to the agx struts as well, I'll let you know when I have driven around on them for a while. Oh, and I have a whiteline anti roll/bump steer adjustment kit ready to go in as well. I'm not sure it will make much difference as my car isn't slammed, but I hear any amount of lowering can be helped with this kit.
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
dscoobydoo
Re: Cut Bump Stops or not?
Post by dscoobydoo »
The bump stops are meant to limit the compression travel to an acceptable bottom level. If you cut them, you are monkeying with alignment when they go below bottom, as well as spring compression and shock travel. I say keep them stock.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Yeah, just keep the bump stops as they are.
jamal
Vendor
Vendor
Post by jamal »
I'd cut them. Most lowering springs these days come with shorter stops or will say to cut them in the directions. Otherwise you are hitting them all the time which will degrade your ride and handling.
macipusy
Post by macipusy »
I always cut them when using lowering springs.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
