stumbles and dies 94 turbo
Someperson
Post by Someperson »
Thinking it's the MAF but wanted opinions, dies unless you step on the gas. Was run through mud, lots and lots of mud. poor girl
93 Winestone TW project
Re: stumbles and dies 94 turbo
I've deleted your bump posts. Please do not bump your own posts like that.
Regarding your problem, can you provide any additional details? Without any more information, it's going to be hard to try and provide suggestions.
Have you pulled the MAF to look at it?
Probably sucked up a ton of water or mud. Did you take the maf off to look inside your intake? Did you take your maf sensor out of the housing to see if it was wet or cleaned it with MAF Sensor Cleaner? Do you have stock intake or a cone filter?
Someperson
Stock intake, haven't picked it up yet so i'll give you more info when i pull it apart. Pics of engine bay in the what did you do to your subie today thread.
