Can Dashcommand app work on my 94 EJ22T?
oleman77
Post by oleman77 »
Not sure where to post this question so I will start with Engine discussion. I am wanting to see much horsepower, fuel economy, engine codes, power, torque, etc I have.... I have been looking at the Dashcommand app that I can use with my iPad. It requires a OBDII port to acquire the data from the computer (I assume). I have a 1994 turbo wagon power of course by a EJ22T. Right now its all stock but do have some mods I would like to do. I have looked high and low under dash and cannot find anything that looks close to a OBDII port. What I have found is a few ports that I have no idea what they are and was wondering if there is an adapter that I can use that will allow me to use Dashcommand. Here are the pics of that I have:
http://s1093.beta.photobucket.com/user/ ... sort=3&o=0
http://s1093.beta.photobucket.com/user/ ... sort=3&o=1
Thanks fella's....
1994 Legacy Sport Wagon (EJ22T)
1977 Leone 4X4 Wagon (EA72)
Re: Can Dashcommand app work on my 94 EJ22T?
Hi, unfortunately the 90-94 legacy models don't have obd-ii electronics. Subaru started with obd-ii compliant cars in 1995 with the legacy model, where most, but not all were compatible.
oleman77
Post by oleman77 »
mike-tracy wrote:Hi, unfortunately the 90-94 legacy models don't have obd-ii electronics. Subaru started with obd-ii compliant cars in 1995 with the legacy model, where most, but not all were compatible.
So the pics of the ports are for something else? What are my options? Newer ECU?
I moved your thread to the electrical forum.
You can try this:
http://bbs.legacycentral.org/viewtopic.php?t=16219
There is one or two other options out there that utilize the same Subaru Select Monitor protocols, but have a little bit different interface.
