Need JDM part help
2.2TLegacy
Need JDM part help
Post by 2.2TLegacy »
Once again i am having problems sourcing JDM parts for my car (or substitute parts from a USDM that will work).
What I am looking for: Injector seals ---> from rail to intake manifold
What is on the car: ej20g manifold
ej20g injector rails (P/N - 17523AA040 for the LH side)
440cc gray top injectors
Thanks for the help guys.
'93 Stroker T-Leg - Weisco forged internals, 440cc gray tops, VF39, '06 TMIC, EJ20G heads & intake manifold, EJ25 phase 1 crank, JDM STi 5-speed mated to 4.11 lsd rear end
2.2TLegacy
Re: Need JDM part help
Im pretty sure what I am looking for is PN 16697AA000. Can anyone verify?
2.2TLegacy
Yeah it looks like in that thread the part i am looking for is the 16696AA000. I got the pn i put above from a JDM parts catalog. When i put both part numbers into 1stsubaruparts:
16696AA000 - Injector Spacer
16697AA000 - Injector Ring (#8 in the link below)
http://opposedforces.com/parts/impreza/ ... tration_1/
The part I need is #8 but I am not sure if that is the "correct" application for me.
#8 is essentially a rubber gasket/ring that is used to seal between the injector rails and intake manifold. The ej22t manifolds have them, but they may be different sizes than the ej20g.
2.2TLegacy
thats exactly the part i am after. Just hope i chose wisely because at $20/each from the stealership, this shit aint cheap
Do you have a spare ej22 or can you go to a junkyard and grab some used ones to try out? I honestly don't know if they'll be that different, and if you can get some easily, it might be worth trying to see if they're the same size or close enough to work.
