this should fit my 91 ss right?
				ride_child
ive studied the sticky and i think they should work. but i just wanted to verify they would. the tokico website said they fit a 2002 wrx. thanks!
							Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
				ride_child
Re: this should fit my 91 ss right?
haha i didnt list what i was looking at. tokico DSK513, complete shock and spring setup.
							Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Does it include tophats?  Cause the rear WRX tophats don't fit our cars.  You'd need GC Impreza-application tophats unless you want to drill out your rears.
The strut fits in the stock top just fine. The issues will be a lack of negative camber and a possible ride height change.
				ride_child
doesnt come with tophats. would the lack of negative camber be fixable? and raise or lower my ride height? thanks guys!
							Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
We installed 03 WRX strut assemblies with GC tophats on a 91 L sedan and it did lift the car about 3/4" That being said you could get lowering springs for a WRX to cancel it out. As for the camber issue you would have to get something like an Ingalls Camber Kit, camber plates, slot the mounting holes at the base of the strut or get adjustable lateral links.
							92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
				ride_child
so just to be clear, i need to get gc top hats for all four corners and an ingalls camber kit for all four corners, and this suspension set up will work? thanks for the help!
							Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Jamal said you can reuse your old tophats.  That being said, Group-N GC tophats would be a sweet upgrade.  Have them on my SS, and they are a huge upgrade over worn out old ones.
				ride_child
would the camber kit be for a gc or wrx?
							Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
				oldscoobyturbo
I've used several wrx suspension setups and only used camber bolts to correctly align the car
							Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
