brief history, Did some work on the girlfriend's brother's car. His transmission and clutch went out. Couldn't find a 3.90 transmission so we converted it to a 4.11 drive train.
Currently the rear diff will bolt right up to 89-94 legacy. If you want to put it into an Impreza or 95+ legacy you will need to swap out the diff cover.
I will separate as follows, Rear diff w/ driveline piece 75 bucks. Axles 60 for both or 40 a piece. rear driveline piece alone is 30. These prices are considerably less than what I paid for them when I did the 4.11 conversion.
Call CJ 253 332 8158
Picture of the parts
