guy parting out a wrx
Fearnoevo
Post by Fearnoevo »
there is a guy parting out an 04 wrx in my town.
would the turbo and intercooler fit without me spending any major cash? also, while its there what els should i get off of it? Steering wheel? seats? shift linkage? will it all fit okay?
thanks-hayden
1996 outback sport $6000 worth of mods:Sold.
1992 legacy ss: MBC.. waiting for more.
Thesubielover
Re: guy parting out a wrx
Post by Thesubielover »
The 04 doesnt fit unless you physically bash in your fire wall above the throttle body. you want a 06 wrx intercooler or i think an 08 forester xt intercooler. when you do the swap, youll have to re route the coolant tank. The oem black ones are shitty anyways. The breakdown and turn into a cardboard like substance.
SiCkSTi04
Post by SiCkSTi04 »
turbo td04, metal coolant tank, interior seats, swaybars with end-links/mounts. any mods?
The shifter linkage and joint will swap also.
Fearnoevo
Post by Fearnoevo »
That's what I figured about the intercooler, it's got upgraded front and rear sway bars, and I'm going to pick up the shift linkage. I want to do a cobb short shifter. Will that work?
Yes the cobb short shifter for the 03 wrx should work with that linkage. You need to grab the shifter joint that goes on the shifter fork as well, since it will be different then your stock one.
turboleg
Post by turboleg »
Where are you located I may be interested in his shell if it's any good.
- Findlay
http://www.toolsource.com
Fearnoevo
Post by Fearnoevo »
the shell is trashed. its been wrecked
