I can't seem to find any resources on sohc Subies doing this, so I'm asking for help/pointers before I decide to get started.
I plan on deleting power steering anyway, and I have no A/C compressor. So I am fine with moving my alternator to a better spot.
My car will be a track car/summer car, but I do not want to spend a ton of money making power. I have a TD04 installed with no intercooler. I have 3" TBE. I have 04 sti exhaust manifold, and perrin up pipe. I know I can go top mount, but was thinking of just doing front mount since I will be in there messing about either way. I like to fabricate parts, so I don't mind making some custom stuff. I also see it as a good opportunity to freshen up some cracking coolant lines and new sensors. I have 360k kms on the car now
My goal is to have nice low intake temps, stock internals, a modest 225+ crank hp, stock ecu hopefully, stock injectors hopefully... I would like it to be reliable DD hp.
This is what I think needs doing; whats involved, and what am I forgetting?
Injector wiring?
Fuel lines? (my hard lines under the manifold are rusted to crap)
Throttle cable lengthen?
Throttle body 'neck' adapter to clear hood?
Cutting bumper beam support.
Move alternator. Any aftermarket brackets that already exist before I go and make one?
Thanks for any help and input! PS I'm partially doing this for looks under the hood, as I realize TMIC is probably most efficient and cheap at my goal power levels...but I just have to be different!
