WTB: Turbo ECU
WTB: Turbo ECU
I started my car to leave work tonight and drove it 10 feet and it died. CEL has been on since I did AT to MT swap a few months ago and it went out as the motor died. It spins over fine and sounds healthy just makes no attempt at firing and I didn't hear the fuel pump. I think I have a spare ECU, but figured I'd see what you guys have around before I attack my storage unit.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Re: WTB: Turbo ECU
I have one, if you need it. But look further into the problem first. It kinda sounds like a bad main relay or connection to me.
Re: WTB: Turbo ECU
Thanks for the suggestion. It was a bit odd how it died so quick and clean. Would the main relay be in the box under the hood?
Re: WTB: Turbo ECU
what is your fuel pressure reading
Re: WTB: Turbo ECU
It died at work last night and I haven't had time to mess with it yet. I don't think the fuel pump was running when I tried to restart.
Re: WTB: Turbo ECU
Perhaps this is thread for the electrical section?
Do any/all of the usual lights come on when you turn the key to 'run'?
Re: WTB: Turbo ECU
So, I checked all the suspect relays and fuses and everything looked fine. Turned the key and it fired right up. I have no idea what to think of it now. Outside temps have been below zero for the past few nights.
Re: WTB: Turbo ECU
Check all the grounds. Try a harness 'wiggle' test.
