Illumination Fuse for Gauge
robertpaige
Post by robertpaige »
I'm wondering if I can just shove the 12+ wire in with the #9 fuse for Dash Illumi. and then just run my ground to my amplifier grounding...
So basically, put the wire in the fuse slot, then push the fuse into the slot. Would that work?
oldscoobyturbo
Re: Illumination Fuse for Gauge
Post by oldscoobyturbo »
I would not go that route its not very safe. Your much better off getting some line taps to add power connections
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
martimus919
Post by martimus919 »
Cool little thing I use that should be shared:
Fuse Tap
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
That is a cool little thing, but i would be scared that something would eventually ground out on it.
robertpaige
I went and picked up a fuse tap. It's a little bit better constructed than the ones above, it seems to be working great!
What are you using this for??
If it's to get illumination for a boost gauge or some other device so it dims with the factory dash lights, you need to run the ground to the illumination system's ground. It has an isolated ground that is NOT the same as the common chassis ground.
robertpaige
I'm using it for a boost gauge. I ran my ground to the ground on my amplifier. I don't care about it dimming with the dash lights, I just wanted it to turn on when I turned on my parking lights/headlights and then turn off when I turn off the car, and it does and works well!
Do you know where that isolated ground is running to? Just a good thing to know..
It runs back to the illumination control unit.
