What is the best way of removing the fuel pump relay? I have seen pictures of the relay location with the dash removed, but I would like to try not to remove the dash.
Seems like its going to be a PITA anyway, but how should I try to access the relay for testing and removal. I have looked under the dash, and it looks tight from every direction.
How to access the fuel pump relay
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
alexandermf
Re: How to access the fuel pump relay
Took me about 30 mins... Take the fuse panel out and work your way up... I had to disconnect lots of harnesses to reach it
Yeah, even with the dash out, getting it from the bottom side is your best bet. That's how I'm probably going to have to do it.
oldscoobyturbo
your both correct the only easy way to get at the fuel pump relay is with the dash completely removed.
if you have a long flat head screw driver you can pop the relay off the bracket much easier than unbolting it. Then the slack in the wiring will allow you to reach it from underneath the dash
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
I actually just messed with the relays yesterday and getting it off with the dash out and the crash bar removed wasn't too bad. I'll post some pictures hopefully later today.
Here are some pictures of the various relays from my work yesterday.
http://www.main.experiencetherave.com/s ... spdswap/21
alexandermf
Idk about other ppl but I got it out just fine with the dash in
Can someone please tell me where the fuel pump relay is located? There are 3 black relays above the interior fuse panel. Is it one of those?
NVM, I think I just found a pic.
