anyone have this problem? fresh n/a>turbo swap high idle
Posted: Tue Jan 08, 2013 6:00 am
by WagonMafia
I just swapped my n/a 5mt wagon with the motor from a 92 SS auto, and I just can't the idle to be CHILL OUT! Now, my turbo inlet pipe is JUNK, ordered one from Canada should get it soon. Who knows about this 'Trans. I.D.' wire to ecu have anything to do with this? I pulled it (black w/white tracer I believe) and with all my vacuum leaks at the time, it was hard to tell if it did anything. Like I said, most vacuum leaks fixed soon I hope, we'll see from there.
Re: anyone have this problem? fresh n/a>turbo swap high idle
Posted: Tue Jan 08, 2013 8:55 pm
by wtdash
You don't need to mess w/the Trans ID wire in your situation....only if you were swapping the transmission from AT>>5-speed.
If you're running the TURBO ECU it doesn't care what trans you have - ECUs are the same for both 5-speeds and Autos.
Until you get a good 90° elbow and can verify you have no leaks, you won't know for sure....and neither will we. :-)
GL,
Td
Posted: Tue Jan 08, 2013 9:45 pm
by WagonMafia
Yeah, I didn't think it mattered. Ermergad I can't wait for the elbow to show up. That will narrow my broad search for never-ending vac leaks. Also, how does replacing broken knock sensor sound? Yeah for $10 I can get a new a/m one and hopefully further narrow my search for issues down. Budget motor swaps suuuuck, but I needed to do it.
Posted: Tue Jan 08, 2013 11:32 pm
by wtdash
Replace the KS, yes....the one from your old engine will work too. But new for $10 is a good deal.
TD
Posted: Wed Jan 09, 2013 3:47 pm
by WagonMafia
KS from old car bunk too. Both cracked. Now I'm getting intermittent start. It'll crank all day, and I'm getting a cel with a bunch of codes. Grrrrrr
Posted: Wed Jan 09, 2013 6:19 pm
WagonMafia wrote:Who knows about this 'Trans. I.D.' wire to ecu have anything to do with this? I pulled it (black w/white tracer I believe)...
So did you do anything with the trans id pin/wire?
WagonMafia wrote:It'll crank all day, and I'm getting a cel with a bunch of codes. Grrrrrr
What codes are you getting?
Posted: Wed Jan 09, 2013 10:41 pm
by WagonMafia
I put the trans ID pin back in to the ecu, I'm not even sure it made any difference. I've got so many drivabilty issues its hard to narrow it down to one problem. At least it starts and will run right now.
