Take a look at these two diagrams, specifically the numbering for the B46 connector
http://www.main.experiencetherave.com/s ... _page1.jpg
http://www.surrealmirage.com/subaru/fil ... ntrol2.jpg
The numbering for the B46 connector when looking at the TCU I/O is oriented as if you are looking directly at the TCU connector. The number 1 pin is located in the top right corner, and looks something like this:
Code: Select all
10 09 08 07 06 05 04 03 02 01
20 19 18 17 16 15 14 13 12 11
Code: Select all
01 02 03 04 05 06 07 08 09 10
11 12 13 14 15 16 17 18 19 20
If you can picture it in your head when you put the TCU connector and the chassis connector together the numbering matches up. So as you can see, depending on what diagram you are looking at and how it has the number orientation laid out, that can make a difference on how you read which pin number is which. This scan from the fsm also shows what I'm talking about.
http://www.main.experiencetherave.com/s ... ectors.pdf
Another good way of verifying you have the correct pin to make sure the wire color matches what's in the diagram. Hopefully this will be helpful for those of you that are just getting into reading electrical diagrams.
