vf43
keithmoilanen
vf43
Post by keithmoilanen »
found one for a good price. should i get it and will it be fine to put into my car? or get a twin scrolled vf 37? or buy a td05? i have a td04 that i was thinking to put in?
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Re: vf43
Just use your td04. You're getting ahead of yourself here. Any bigger and you need supporting mods. Injectors, engine management, dohc heads or performance cams, upgraded fuel pump, wideband o2 sensor and gauge, intercooler (even with td04), exhaust, etc. Seems you have a lot of research to do on these cars. Maybe suspension mods are a better choice for added fun in handling. Cheaper and sometimes more noticeable and safer. New performance tires too and brakes can't hurt or new performance pads and new rotors. Upgrade brake lines. Lightweight wheels are a good mod. Lightened flywheel or pulleys. Lots of ideas. Just realize if its more power you want its gonna cost a lot of money. Estimate a total and multiply that by 3 and you may be in the ballpark of what you wind up spending in the end.
wtdash
Re: vf43
Post by wtdash »
kimokalihi wrote: Estimate a total and multiply that by 3 and you may be in the ballpark of what you wind up spending in the end.
Agreed.
If you get the VF43 - a good turbo for spool and top end- get the Rob Tuned ECU and supporting mods.
Put the TD04 in now, presumably w/an IC and run that to see if you want "MORE".
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
keithmoilanen
Re: vf43
i have a tmic already and exhaust so i guess i should just install the tdo4.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Re: vf43
kimo what suspension set up should i go with i have 17in rims. and go off road a lot.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
MikeyMeyagi
Re: vf43
Post by MikeyMeyagi »
i ran a vf39 on stock management with a fmic and dohc heads, ran good, made decent power. kept it under boost cut and my afr's were fine.
*sold*
keithmoilanen
Re: vf43
so i should find some heads swap in turbo then work on suspension
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Re: vf43
is a vf11 the size smaller than the tdo4
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
wtdash
Re: vf43
Post by wtdash »
keithmoilanen wrote:is a vf11 the size smaller than the tdo4
Yes.
And for future reference the #'s after a VFxx such as VF11, VF43, etc. refer to the chronological order /age, NOT the size.
For the US STi there is the VF39, VF43 and VF48 from '04-'12 (last I read) - they are all very similar in size.
The largest turbo in the VF series is the VF22 (IIRC), which was used back in the late 90's on the WRX/STi.
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
keithmoilanen
Re: vf43
thanks very much i love this site people are so helpful i am learning so much. what part of idaho are you in i am around the boise area.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
MikeyMeyagi
Re: vf43
get yourself a set of 97-99 dohc 2.5 heads and the intake manifold. huge improvement over the 2.2 heads with their dinky ports and valves.
*sold*
keithmoilanen
Re: vf43
Where should I look for them.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
matt00rs25
Re: vf43
Post by matt00rs25 »
nasioc or rs25
92ColoradoTurbo
Re: vf43
Post by 92ColoradoTurbo »
MikeyMeyagi wrote:get yourself a set of 97-99 dohc 2.5 heads and the intake manifold. huge improvement over the 2.2 heads with their dinky ports and valves.
Does this require any other supporting mods? or do they just slap right on like legos?
Chris
1992 SS Liquid Silver Metallic 5MT AWD, 3in TBE, TD04, 06 TMIC, MBC, Coffee Cup Mod, 04 STi Struts
Re: vf43
You have to drill and tap the passenger side head for coolant and oil for the turbo. Pretty easy to do before you install them.
Someperson
Re: vf43
Post by Someperson »
timing covers, coolant crossover pipe
93 Winestone TW project
92ss satinsvoice
Re: vf43
Post by 92ss satinsvoice »
Don't forget the oil dip stick pipe. The stock one will not bolt up the the dohc heads . Plus you don't have to tap the head for waterline for the turbo. Just hook them up with the heater core. But tap the oil return though, that's a must.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Re: vf43
92ss satinsvoice wrote:Don't forget the oil dip stick pipe. The stock one will not bolt up the the dohc heads . Plus you don't have to tap the head for waterline for the turbo. Just hook them up with the heater core. But tap the oil return though, that's a must.
That's a great way to get hotter heat to your blower motor!!!!! :-D
