Turbo Cam question
Turbo Cam question
Im building an ej22t out of an ej22 is there any turbo cams I can get
Re: Turbo Cam question
I put your post in it's own thread, as it's not related to the one you posted in.
Welcome to the forum!
Welcome to the BBS.
The ej22t cams are slightly different than the ej22 cams. The turbo cams have slightly differen overlap and duration. If you want some more agressive cams, I'd suggest checking out the 220 grind from http://www.deltacam.com
