Boost w/o MAF, no boost w/ MAF, bad MAF?
tsbpenguin
Post by tsbpenguin »
Got the ej22t swap back on the road today and it is acting funky. With MAF plugged in it it will start and idle fine, and starts to pull from a stop just fine but once the vacuum starts to creep towards 0 boost, the car sputters, hesitates, and won't accelerate or build any boost at all. If I unplug the MAF, the car starts, but will die at idle if I don't keep the rpm's up. Once on the road, it starts to pull, hesitates and sputters a bit around 0 boost, but if i stay on it it stops sputtering at about 5psi, builds full boost (MBC set at 10) and feels like it is pulling great. No engine codes at all (except when I unplug the MAF and then of course it throws a MAF code.) Sound like a bad MAF, or is there anything else I should check first? Thanks!
In between Subies
tsbpenguin
Re: Boost w/o MAF, no boost w/ MAF, bad MAF?
Took it for another road test and wanted to clarify what happens when the MAF is unplugged. I still can't go WOT right away, it will cut out at 0 boost, but if I go part throttle until it starts to build boost, then I can go WOT and it will fully boost and pull. This makes me think it's not the MAF but maybe pressure exchange solenoid? Just seems like it's having a really hard time switching out of vacuum into boost.
In between Subies
If you happen to need a new maf, I have one for sale. Have you checked the vacuum diagram in the stickies? You could have a line backwards somewhere or not hooked up at all. If you also happen to need a wastegate solenoid or pressure exchange solenoid, i have those for sale as well.
Alphius
Post by Alphius »
Do you have a check engine light or any codes stored by the ECU?
tsbpenguin
Not sure how I didn't notice it before, but ended up being that the driver's side fuel rail had no bolts, and thus nothing holding it down. Fixed that, tightened up a couple intake clamps, and voila she runs like a champ. Boost feels great :D
In between Subies
Awesome!!!
