Legacy Central header for the prosilver theme?
Let us know what you think about the site and the forums and give us your suggestions on how to make them better.
James614
Post by James614 »
Just switched to the lighter theme because I mostly browse the forum in sunlight right now on a phone screen. Much easier to read, but I was just wondering if it was possible the header with the rotating pictures could be implemented into this theme? Its really not a big deal since I know you guys prefer not to do hacks and I'm probably the only one actually using the theme. But I figured I'd ask anyway in case its an easy thing to put in there.
The forum just doesn't have the same "Subaruness" without it.
Re: Legacy Central header for the prosilver theme?
I'll check with Dave since he's the one that handles the backend work. I'll let you know what I find out.
