Car pulls right under braking- possible bad MC?
biggreen96
Post by biggreen96 »
Passenger front locks up quite a bit sooner than the drivers front, feels like it's getting twice as much clamping force than the left side.
So I replaced the caliper piston seals and the slider pins(which were sticky) on each caliper for good measure. Bled it good.
It still pulled.
So I swapped pads side to side in a last ditch attempt as it was getting dark.
Still pulls.
Has anybody experienced a master cylinder issue that caused the car to pull in either direction?
matt00rs25
Post by matt00rs25 »
I had an old camaro that did that. Was the master on that one. Did you change the rubber lines by chance.
biggreen96
Re: Car pulls right under braking- possible bad MC?
Dave replaced them with braided lines before I bought the car years ago.
