I'm doing the Robtune ECU swap, and need an ECU case from a 1st-gen N/A car to mount it in based on what I'm reading in the forums.
Does anyone have an N/A ECU laying around for cheap? Thanks!
Wanted: 90-94 Legacy N/A ECU
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
Re: Wanted: 90-94 Legacy N/A ECU
Rob has confirmed that the N/A ecu's work with his tune? If you absolutely can't find one on the cheap, then I can grab an ecu from the junkyard - It'll be about $65 shipped.
Its the case to put the chipped 20g ecu in. I may have an extra i can part with... Offer?
93 Winestone TW project
Yeah, it's just the case that I need. If I got the whole ECU, I'd turn around and send the board to Rob for his continuing research, as I don't need the actual circuitry.
Someperson, I was hoping for something in the $20 shipped range. If you can do that, let me know.
Mike, if nothing pans out I'll get in touch.
It will fit in a combo of the EJ22T case and the EJ20G, per Rob's post HERE.
I did it and worked OK.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
