front brake grinding into the rotor?
dafrompa
Post by dafrompa »
a day or two ago i notice a wide sound coming from my drive side front brakes and all so saw my rotor getting really stracked up their new rotors and brake that i put on almost a year ago. i don't know what could throw the caliper off balance. i replaced retaining clips and still nothing changed.
dafrompa
Re: front brake grinding into the rotor?
Post by dafrompa »
Could my rotor be warped?
matt00rs25
Post by matt00rs25 »
You'd feel it if it was warped. Heavy vibration under braking.
dafrompa
Post by dafrompa »
i feel it more when turn the wheel slightly left
dafrompa
Post by dafrompa »
Could bad ball joint make my wheel push to the outside. The side of my rotor that is damaged is the outside rotor the inside looks untouched.
Also may want to look at the wheel bearing.
rallyak
Post by rallyak »
I seconded the wheel Bearing, just changed one. It actually broke the caliper bracket it was so bad.
Charles
dafrompa
Post by dafrompa »
figured it out for some reason my axle nut came lose i chage my wheel bearing like six month ago so that was the last time that had that axle off can't believe it took six months for that thing to losen up. torx it down and crimp it again hopefully it dont come lose in another six months lol
matt00rs25
Hopefully the bearing isn't junk now. Did you stake the nut so it couldn't back off this time?
dafrompa
Post by dafrompa »
yeah i did that the frist time tho hopfully it won't come off again
What did you torque the nut to?
dafrompa
Post by dafrompa »
130ft
That's in the proper torque range, 123 - 152 ft-lbs.
