D Spec model numbers and spring question
coffeeman885
Post by coffeeman885 »
Does anybody happen to know what the model numbers are for the D Specs that fit a 94 Leggy? Does anyboy have experience with D specs and AGXs and if so are the Tokicos worth the extra cash?
Also, I am looking for new springs. Any ideas? My main focus is rallycross so I want to keep stock ride height but get better spring rates. The only ones that I know of are King springs and Tein Gravel Master. I have thought about switching to WRX springs although they would drop me an inch and I would loose a lot of spring rate in the rear which I assume would make my car understeer too much.
Speed limits are like herpes - once you get them you will never be rid of them. - Jeremy Clarkson
'94 Legacy L Wagon "Bluella"
Re: D Spec model numbers and spring question
On the springs, King springs are the only ones I know that retain the stock height. Unless you want to go coilover, which I'm not suggesting, I think the two springs you posted are probably your best bet. Hopefully someone else will chime in as well.
