Hose sizes please help??
turboboxer92
Post by turboboxer92 »
I want to replace the oil return lines and all the coolant hoses that plumb to and from the turbo what sizes are they i need to replace and have no idea what size they are. I cant take them off to look because they are so damn brittle if i do they will break and then i have no ride to work please help me. The oil lines to and from the turbo and cooling lines.
Someperson
Re: Hose sizes please help??
Post by Someperson »
josh may have part numbers so you can find oem replacements
93 Winestone TW project
turboboxer92
ok and also this would be the first time i start taking apart engine components i cant imagine how delicate they are im just afraid i wont be able to find or replace them if that happens. the rason for the overhaul is the bad valve cover gasket leak. My boost seems to be irradic at times as well. i bet i have all kinds of leaks somewhere idk like i said i just want to do this right the first time.
Someperson
mine are leaking like a siv, i like tu run it for a few mins every week, but its pouring onto the mani and now im afraid of a fire... its a parts wagon but still... so i understand ur pain.,..
turboboxer92
but thats the thing haha mine is my daily driver and cant afford a fire either so also would a clogged cat cause the turbo to sputter and cause shuttering in power?
The oil return hose p/n is 807515712
The coolant hose from the head's p/n is 807611202
The coolant hose that goes to the coolant tank's p/n is 807611172
turboboxer92
thanks man i really appreciate the help
