Non abs bleeding procedure
Someperson
Post by Someperson »
Same as ur standard bleed? Pass rear drivers rear pass front drivers front?
93 Winestone TW project
Re: Non abs bleeding procedure
On these cars, you need to bleed the brakes in an X pattern.
I believe the non ABS procedure is: Pass Front, Driver Rear, Driver Front, Pass Rear. I usually do this twice to get nice pedal feel.
Someperson
Thanks, thats prob y my pedal is a wet sponge still...
Just to confirm, that bleeding procedure is the same regardless of whether you have abs or non-abs.
Someperson
Thanks a ton josh! You have an email btw
Someperson
bump so i can find it tomorrow
