This meet will take place the second Saturday of August, the tenth. Again to accommodate all members within Colorados range we will be meeting in Denver at the red rocks amphitheatre like last time!! We won't need permits and whatnot so don't sorry, we are simply using this as a meeting spot only.... Upper lot by the actual amphitheatre!
Time to meet at red rocks will be 11am-12noon, once noon rolls around the group will head out for the cruising part
We will be cruising from red rocks to lookout mountain which is roughly 20-30 mins drive if you check any maps app. Here is a mini map I've taken a shot of the said cruise. I heard those roads were great for scenery and cruising so we can take some pics as well when we get there, maybe some action shots on the way
I figure from lookout mountain we can go grab a bite and crash a local food joint closer in the city... Location: TWIN PEAKS RESTAURANT
Once we are done cruising to Lookout mountain everyone is more than welcome to come grab a bite with the group at Twin Peaks
All makes and models welcome, spread the word to anyone you know that might wanna come or who you know drives a first gen that normally doesn't visit the forums here often. Go ahead and mark your calendars and request that date off with work or other duties.
Checklist to bring:
-Enough gas to last a couple hours of cruising, fillup BEFORE hand preez.
-snacks, water anything you'll want to keep your stomach held over until we get lunch around 1-2pm ish
-general lookover of your vehicle to make sure its safe to drive, no inspections will be taking place, drive at your own risk and have a good time, we should all have a good time like last time!!
