Sedan/Wagon doors differences
GedasT4
Post by GedasT4 »
Hi,
I'm looking for both right side doors, and have faced with a question (some may find it absurd..., but still).
Does the wagon and sedan have different rear doors? Also does the pre-facelift and facelift doors have any differences, or any 89-94 leggy doors would fit?
Thank you in advance for your answers :)
'93 2.2 Sedan, WRX Turbo swap running on ethanol, MT, Low Range Gear, LSD, dark green, leather
Europe, Lithuania, Vilnius
rallyak
Re: Sedan/Wagon doors differences
Post by rallyak »
The doors are interchangeable from 89-94 with a few exceptions to the rear door between wagon and sedan. The glass in the rear door and upper door moulding is the only difference.
Charles
Yeah, the actual metal door should be interchangable between the 90-94 MY's and between wagons & sedans. The only note I see in the parts book is that there are two different part numbers, one for cars that were made in Japan and one for cars that were made in the US. I doubt there were any physical differences though.
GedasT4
Post by GedasT4 »
OK, thanks for the info :)
davelegacy
Post by davelegacy »
Glass different shape as said above
