Out of the ss game for now, not the subaru parts selling game though/ See list below
From 04 FXT
1. Front cross-member turbo - $70
2. Front control arms, no rear bushing - $50
3. Front turbo subframe - $65
4. Steering rack 120k - $20
5. Steering knuckle -$30
6. auto trans- starter - $40
7. auto trans, some slipping before swap, 130 k - $80 ([use as core of whatever)
8. auto trans mount - $20
9. auto trans front cv axles (2) - SOLD
10. auto trans drive shaft - $45
11. auto instrument cluster $40
12. rear cv axles - $SOLD
13. rear VSLD differential - $225
14. rear subframe/crossmember - $65
15. 5 speed trans mount - $60
16. 5 speed drive shaft - $75
17. Rear Sway Bar w/ new prothane bushing - $50
18. front calipers and brackets - $50
31. 20 Ichiba wheel studs stock size - $20
32. XT headers SOLD
33. Heat Shields - $50
19. blown short block, seized - $100
From other Subarus
20. Impreza Rear Sway Bar Perch $30
21. WRX 02 -03 20mm rear sway bar SOLD
22. WRX 04 - 05 sedan control arms with all bushings 60k on them - $110
23. WRX 06 brake booster - $40
24. 07 sti stock headers cross pipe SOLD
25. Ebay FMIC 28" 9" 2.75", 2.75" openings - $50
26. Whiteline Roll Center adjustment ball joints only, one new, one with about 5k - $60
27. EJ22t heads for the set - $200
28. VF11 turbo - $40
29. SPARCO seat - $120
30. WRX Dash Beam - $40
04 FXT various parts, and other subaru parts NJ
njdriver04
'04 forester XT
Scoob Alumni
'94 TW, '96 L, '00 GT
Scoob Alumni
